Can you add a Method like getAssignments Method?
CLASS: WorkflowAssignmentDao,  add processRequesterId param for the funciton
public Collection<WorkflowAssignment> getAssignments(String packageId, String processDefId, String processId, String activityDefId, String username, String state, String sort, Boolean desc, Integer start, Integer rows)
      Hi, I found the code mentioned in GitHub. You could try to customize the code either in a custom plugin or using BeanShell.
