You need to use the "Grouping" feature. If you are using hardcoded values then the third column of the configuration.
If you are using sql query then the third attribute/column will represent the grouping field.
e.g.
SELECT id, label, field1 FROM btable
thanks is working
i have 2 select box . select 1 are parent value . select 2 is child from select 1 . so how i can set that
for example:
so i want my select 2 can get value like that after select 1 is picked or change
