There are a way to apply a filter in a dropdown list located in a Spreadsheet based in a selected value located in Select Box?
Hi experts , I'm using a dropdown field located a spredsheet, but I would like filter the options in this field based in a value in a field located in the form.  Is it possible?
      You can make use of the Custom HTML to achieve the feature that you are looking for.
      Hope this KB Help too! Spreadsheet Deep Customizations.
      Regards
