i want reissue  this Issue Subform Repeater when insert or submit second time .
now i have video for see what happen when you insert or submit second time on subform repeater
video issue subform repeater.mp4
  1. when in insert or submit first time data insert correctly.
  2. open link again and just do save without change anything
  3. after save the data in DB change to duplicate
how i can fix this ?
      I have tested on my end using 8.0.12 and 8.1.2 with the latest plugin release 7.0.10
      However, the issue is not replicated.
      Have you check your subform repeater version?
      might as well try to upgrade to the latest version (7.0.10) : https://github.com/jogetoss/subform-repeater/releases
      Thanks!
      1. galvin
        my Joget Version: 6.0.15  and my latest plugin is 7.0.7 .
        i already try upload plugin 7.0.10 but didn;t stay on plugin .
        edited answer
        after i try plugin 7.0.9 is working perfectly . thanks for the help
