Hi ,
I 'm creating a healthcare application and using Jasper report to create medical prescription.
Joget v6 Beat 3 and Jaspersoft Studio 6.4.0
The issue is when I copy and paste the JRXML generated from the Jaspersoft into Joget the defaul HTML display i showing spaces between lines ..as below showing few lines from report.
I have tried using below properties from jaspersoft but that didn't help
<property name="net.sf.jasperreports.export.ignore.page.margins" value="true"/>
<property name="net.sf.jasperreports.engine.type.LineSpacingEnum" value="single"/>
I also tried - isRemoveLineWhenBlank="true" on the elements. - No luck
Wellness Care Kendra
Visit Date Tue Oct 03 11:37:51
Registration # 020920170084  Bhushan  Patel : M :  36
However when  I select the PDF option at bottom I get as desired
Any idea how to rectify this problem .
      you are right , I checked and it seems to be influenced by css
        From my experience, there's shortcoming in the HTML web browser view just like what you claimed but the .pdf generation at the bottom of the page will render things correctly as per what you will expect from jasper studio itself.
        Probably the HTML view is more complicated and influenced by the webpage's css and javascript making rendering imperfect.
          read band height *
            Hi Anders, i tried reducing band width , it didn't help either ..anymore more thoughts/suggestions would help
              tnanks for suggestion let me try reducing band height value ...meanwhile pasting the JRXML
              <?xml version="1.0" encoding="UTF-8"?>
              <!-- Created with Jaspersoft Studio version 6.4.0.final using JasperReports Library version 6.4.1  -->
              <jasperReport xmlns="http://jasperreports.sourceforge.net/jasperreports" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://jasperreports.sourceforge.net/jasperreports http://jasperreports.sourceforge.net/xsd/jasperreport.xsd" name="Invoice_Table_Based_3" pageWidth="595" pageHeight="842" whenNoDataType="NoPages" columnWidth="535" leftMargin="20" rightMargin="20" topMargin="0" bottomMargin="0" uuid="4eedbb89-b4f6-4469-9ab6-f642a1688cf7">
                  <property name="template.engine" value="tabular_template"/>
                  <property name="com.jaspersoft.studio.data.sql.tables" value=""/>
                  <property name="com.jaspersoft.studio.data.defaultdataadapter" value="Meds project"/>
                  <style name="Title" forecolor="#FFFFFF" fontName="Times New Roman" fontSize="50" isBold="false" pdfFontName="Times-Bold"/>
                  <style name="SubTitle" forecolor="#CCCCCC" fontName="Times New Roman" fontSize="18" isBold="false" pdfFontName="Times-Roman"/>
                  <style name="Column header" forecolor="#666666" fontName="Times New Roman" fontSize="14" isBold="true" pdfFontName="Times-Roman"/>
                  <style name="Detail" mode="Transparent" fontName="Times New Roman" pdfFontName="Times-Roman"/>
                  <style name="Row" mode="Transparent" fontName="Times New Roman" pdfFontName="Times-Roman">
                      <conditionalStyle>
                          <conditionExpression><![CDATA[$V{REPORT_COUNT}%2 == 0]]></conditionExpression>
                          <style mode="Opaque" backcolor="#EEEFF0"/>
                      </conditionalStyle>
                  </style>
                  <style name="Table">
                      <box>
                          <pen lineWidth="1.0" lineColor="#000000"/>
                          <topPen lineWidth="1.0" lineColor="#000000"/>
                          <leftPen lineWidth="1.0" lineColor="#000000"/>
                          <bottomPen lineWidth="1.0" lineColor="#000000"/>
                          <rightPen lineWidth="1.0" lineColor="#000000"/>
                      </box>
                  </style>
                  <style name="Table_TH" mode="Opaque" backcolor="#F0F8FF">
                      <box>
                          <topPen lineWidth="0.5" lineColor="#000000"/>
                          <bottomPen lineWidth="0.5" lineColor="#000000"/>
                      </box>
                  </style>
                  <style name="Table_CH" mode="Opaque" backcolor="#BFE1FF">
                      <box>
                      </box>
                  </style>
                  <style name="Table_TD" mode="Opaque" backcolor="#FFFFFF">
                      <box>
                      </box>
                  </style>
                  <subDataset name="tableDataset" uuid="46d1fe3a-92a2-4c5a-9fd2-10b24f160cd2">
                      <parameter name="Parameter3" class="java.lang.String"/>
                      <queryString language="SQL">
                          <![CDATA[SELECT * FROM   jwdb.app_fd_patientdiagnosis WHERE c_patientid = $P{Parameter3} LIMIT 3]]>
                      </queryString>
                      <field name="id" class="java.lang.String"/>
                      <field name="dateCreated" class="java.sql.Timestamp"/>
                      <field name="dateModified" class="java.sql.Timestamp"/>
                      <field name="c_field1" class="java.lang.String"/>
                      <field name="c_patientId" class="java.lang.String"/>
                      <field name="c_duration" class="java.lang.String"/>
                      <field name="c_category" class="java.lang.String"/>
                      <field name="c_subcategory" class="java.lang.String"/>
                      <field name="c_jsonrow" class="java.lang.String"/>
                  </subDataset>
                  <subDataset name="Dataset1" uuid="48fa1c7e-99b7-4fa5-85e0-65718bc720f3">
                      <parameter name="Parameter1" class="java.lang.String"/>
                          <![CDATA[SELECT * FROM jwdb.app_fd_patientinvestigation WHERE c_patientid = $P{Parameter1}  ORDER BY c_date desc LIMIT 3]]>
                      </queryString>
                      <field name="c_patientid" class="java.lang.String"/>
                      <field name="c_date" class="java.lang.String"/>
                      <field name="c_investigation" class="java.lang.String"/>
                      <field name="c_value" class="java.lang.String"/>
                      <field name="c_character" class="java.lang.String"/>
                      <field name="c_complain" class="java.lang.String"/>
                  </subDataset>
                  <subDataset name="Dataset2" uuid="4879827b-98a2-4986-a57b-fb78d7c99a49">
                      <parameter name="Parameter4" class="java.lang.String"/>
                          <![CDATA[SELECT * FROM  jwdb.app_fd_patientphyexam WHERE c_patientid = $P{Parameter4}]]>
                      </queryString>
                      <field name="c_parameter" class="java.lang.String"/>
                  </subDataset>
                  <subDataset name="Dataset3" uuid="f769ad55-10d4-4731-ab79-475aa604a6e0">
                      <parameter name="Parameter5" class="java.lang.String"/>
                          <![CDATA[SELECT * FROM jwdb.app_fd_patienttreatment WHERE c_patientid = $P{Parameter5} LIMIT 3]]>
                      </queryString>
                      <field name="c_drug" class="java.lang.String"/>
                      <field name="c_route" class="java.lang.String"/>
                      <field name="c_method" class="java.lang.String"/>
                      <field name="c_frequency" class="java.lang.String"/>
                  </subDataset>
                  <subDataset name="Dataset4" uuid="0248599c-be77-4a95-a4a9-3315cee0bd32">
                      <parameter name="doctors_name" class="java.lang.String"/>
                          <![CDATA[SELECT * FROM  jwdb.app_fd_doctordetail WHERE c_firstName = $P{doctors_name}]]>
                      </queryString>
                      <field name="c_lastName" class="java.lang.String"/>
                      <field name="c_degree4" class="java.lang.String"/>
                      <field name="c_opd3" class="java.lang.String"/>
                      <field name="c_phoneNumber2" class="java.lang.String"/>
                      <field name="c_emailId" class="java.lang.String"/>
                      <field name="c_degree1" class="java.lang.String"/>
                      <field name="c_degree3" class="java.lang.String"/>
                      <field name="c_degree2" class="java.lang.String"/>
                      <field name="c_firstName" class="java.lang.String"/>
                      <field name="c_phoneNumber" class="java.lang.String"/>
                      <field name="c_opd1" class="java.lang.String"/>
                      <field name="c_opd2" class="java.lang.String"/>
                      <field name="c_docRegisteration" class="java.lang.String"/>
                  </subDataset>
                  <parameter name="patient_id" class="java.lang.String">
                      <parameterDescription><![CDATA[]]></parameterDescription>
                  </parameter>
                  <queryString>
                      <![CDATA[SELECT * FROM jwdb.app_fd_patientdetail WHERE id = $P{patient_id}]]>
                  </queryString>
                  <field name="c_reference_id" class="java.lang.String"/>
                  <field name="c_FirstName" class="java.lang.String"/>
                  <field name="c_Address2" class="java.lang.String"/>
                  <field name="c_Gender" class="java.lang.String"/>
                  <field name="c_consultancyFee" class="java.lang.String"/>
                  <field name="c_Address1_1" class="java.lang.String"/>
                  <field name="c_amountDue" class="java.lang.String"/>
                  <field name="c_referredBy" class="java.lang.String"/>
                  <field name="c_LastName" class="java.lang.String"/>
                  <field name="c_guardian" class="java.lang.String"/>
                  <field name="c_doctorsName" class="java.lang.String"/>
                  <field name="c_Age" class="java.lang.String"/>
                  <field name="c_page2_key" class="java.lang.String"/>
                  <field name="c_page3_key" class="java.lang.String"/>
                  <field name="c_page1_key" class="java.lang.String"/>
                  <field name="c_page4_key" class="java.lang.String"/>
                  <field name="c_page5_key" class="java.lang.String"/>
                  <field name="c_field20" class="java.lang.String"/>
                  <field name="c_patientData_1_1" class="java.lang.String"/>
                  <field name="c_city" class="java.lang.String"/>
                  <field name="c_state" class="java.lang.String"/>
                  <title>
                      <band height="550" splitType="Stretch">
                          <textField pattern="EEEEE dd MMMMM yyyy">
                              <reportElement x="398" y="10" width="151" height="13" isRemoveLineWhenBlank="true" isPrintInFirstWholeBand="true" isPrintWhenDetailOverflows="true" uuid="bb10dbe1-0a4f-4722-9953-c163b63cf979">
                                  <property name="com.jaspersoft.studio.unit.height" value="pixel"/>
                              </reportElement>
                              <textFieldExpression><![CDATA["Visit Date" + " " + new java.util.Date()]]></textFieldExpression>
                          </textField>
                          <textField pattern="">
                              <reportElement x="398" y="26" width="159" height="13" isRemoveLineWhenBlank="true" isPrintInFirstWholeBand="true" uuid="3836ce65-eca3-4cad-a6de-b1818def0a2b">
                                  <property name="com.jaspersoft.studio.unit.x" value="pixel"/>
                                  <property name="com.jaspersoft.studio.unit.width" value="pixel"/>
                                  <property name="com.jaspersoft.studio.unit.y" value="pixel"/>
                              </reportElement>
                              <box>
                                  <topPen lineWidth="0.0" lineStyle="Solid" lineColor="#000000"/>
                                  <leftPen lineWidth="0.0" lineStyle="Solid" lineColor="#000000"/>
                                  <bottomPen lineWidth="0.0" lineStyle="Solid" lineColor="#000000"/>
                                  <rightPen lineWidth="0.0" lineStyle="Solid" lineColor="#000000"/>
                              </box>
                              <textFieldExpression><![CDATA["Registration #" +" "+ $F{c_reference_id}]]></textFieldExpression>
                          </textField>
                          <staticText>
                              <reportElement x="0" y="0" width="250" height="26" isRemoveLineWhenBlank="true" uuid="e622555d-198b-4ccd-a4a1-c59c53304058">
                              </reportElement>
                              <textElement>
                                  <font size="19" isBold="true"/>
                              </textElement>
                              <text><![CDATA[Wellness Care Kendra]]></text>
                          </staticText>
                          <textField>
                              <reportElement x="0" y="27" width="100" height="13" isRemoveLineWhenBlank="true" isPrintInFirstWholeBand="true" uuid="233e056d-03a8-4178-b2cb-ae583966f907">
                              </reportElement>
                              <textFieldExpression><![CDATA[$F{c_doctorsName}]]></textFieldExpression>
                          </textField>
                              <reportElement x="398" y="42" width="300" height="13" isRemoveLineWhenBlank="true" isPrintInFirstWholeBand="true" uuid="f0fc47ab-8082-4ff5-ab3c-b22f6fb14c8c">
                              </reportElement>
                              <textFieldExpression><![CDATA[$F{c_FirstName} + "  "+$F{c_LastName} +" : " + $F{c_Gender} + " :  " + $F{c_Age}]]></textFieldExpression>
                          </textField>
                          <componentElement>
                              <reportElement x="400" y="58" width="100" height="30" isRemoveLineWhenBlank="true" uuid="4c8edc94-d509-48bc-b247-097f424f77b3">
                                  <property name="com.jaspersoft.studio.layout" value="com.jaspersoft.studio.editor.layout.VerticalRowLayout"/>
                                  <property name="com.jaspersoft.studio.table.style.table_header" value="Table 1_TH"/>
                                  <property name="com.jaspersoft.studio.table.style.column_header" value="Table 1_CH"/>
                                  <property name="com.jaspersoft.studio.table.style.detail" value="Table 1_TD"/>
                                  <property name="com.jaspersoft.studio.components.autoresize.next" value="true"/>
                                  <property name="com.jaspersoft.studio.components.autoresize.proportional" value="true"/>
                              </reportElement>
                              <jr:table xmlns:jr="http://jasperreports.sourceforge.net/jasperreports/components" xsi:schemaLocation="http://jasperreports.sourceforge.net/jasperreports/components http://jasperreports.sourceforge.net/xsd/components.xsd">
                                  <datasetRun subDataset="Dataset2" uuid="bf34c2b9-9245-42f3-aeef-7a7b444de690">
                                      <datasetParameter name="Parameter4">
                                          <datasetParameterExpression><![CDATA[$P{patient_id}]]></datasetParameterExpression>
                                      </datasetParameter>
                                      <connectionExpression><![CDATA[$P{REPORT_CONNECTION}]]></connectionExpression>
                                  </datasetRun>
                                  <jr:column width="51" uuid="b1a1065d-8b8b-446f-bb85-862e53eb5e8c">
                                      <jr:detailCell height="30">
                                          <textField>
                                              <reportElement x="0" y="0" width="51" height="30" uuid="67931ed1-4bf0-46b1-bfe4-c4d789a74da8"/>
                                              <textFieldExpression><![CDATA[$F{c_parameter}]]></textFieldExpression>
                                          </textField>
                                      </jr:detailCell>
                                  </jr:column>
                                  <jr:column width="49" uuid="51e87b5a-9875-4080-8e02-324079b8f1ef">
                                          <textField>
                                              <reportElement x="0" y="0" width="49" height="30" uuid="bef0f2bd-0d38-420c-a54a-9fb5f8d79cb4"/>
                                              <textFieldExpression><![CDATA[$F{c_value}]]></textFieldExpression>
                                          </textField>
                                      </jr:detailCell>
                                  </jr:column>
                              </jr:table>
                          </componentElement>
                          <componentElement>
                              <reportElement x="-1" y="58" width="321" height="76" isRemoveLineWhenBlank="true" uuid="2ef4d4c6-866a-4238-8919-e66534b566c0">
                                  <property name="com.jaspersoft.studio.table.style.table_header" value="Table_TH"/>
                                  <property name="com.jaspersoft.studio.table.style.column_header" value="Table_CH"/>
                                  <property name="com.jaspersoft.studio.table.style.detail" value="Table_TD"/>
                              </reportElement>
                                  <datasetRun subDataset="tableDataset" uuid="2e8a3607-be3c-4f6c-b11c-6fab12a3c487">
                                      <datasetParameter name="Parameter3">
                                      </datasetParameter>
                                  </datasetRun>
                                  <jr:column width="66" uuid="0872984e-c077-4414-8d45-ceb57823ce2c">
                                          <textField>
                                              <reportElement x="0" y="0" width="66" height="30" uuid="195046ac-90bc-4630-91fe-53d129a44542"/>
                                              <textFieldExpression><![CDATA[$F{c_duration}]]></textFieldExpression>
                                          </textField>
                                      </jr:detailCell>
                                  </jr:column>
                                  <jr:column width="86" uuid="b01fd96f-b0aa-415a-a42a-cc0128bcc4f4">
                                          <textField>
                                              <reportElement x="0" y="0" width="86" height="30" uuid="886e5c89-0f4a-4b89-8a59-4e4cc4218cb8"/>
                                              <textFieldExpression><![CDATA[$F{c_category}]]></textFieldExpression>
                                          </textField>
                                      </jr:detailCell>
                                  </jr:column>
                                  <jr:column width="108" uuid="3626eaf2-6315-4f2f-a1ac-f12e786c4c58">
                                          <textField>
                                              <reportElement x="0" y="0" width="108" height="30" uuid="9f5a6cc2-447c-425b-8931-ebfca451a2b0"/>
                                              <textFieldExpression><![CDATA[$F{c_subcategory}]]></textFieldExpression>
                                          </textField>
                                      </jr:detailCell>
                                  </jr:column>
                              </jr:table>
                          </componentElement>
                          <componentElement>
                              <reportElement style="Column header" isPrintRepeatedValues="false" x="0" y="250" width="500" height="30" isRemoveLineWhenBlank="true" isPrintWhenDetailOverflows="true" uuid="6bfa381b-dc5c-42c4-95c8-5f12117a7dd6">
                                  <property name="com.jaspersoft.studio.unit.CONTENTS.height" value="pixel"/>
                                  <property name="net.sf.jasperreports.export.headertoolbar.table.name" value="Investigations"/>
                                  <property name="com.jaspersoft.studio.unit.CONTENTS.width" value="pixel"/>
                                  <property name="com.jaspersoft.studio.layout" value="com.jaspersoft.studio.editor.layout.grid.JSSGridBagLayout"/>
                              </reportElement>
                              <jr:list xmlns:jr="http://jasperreports.sourceforge.net/jasperreports/components" xsi:schemaLocation="http://jasperreports.sourceforge.net/jasperreports/components http://jasperreports.sourceforge.net/xsd/components.xsd" printOrder="Vertical" ignoreWidth="true">
                                  <datasetRun subDataset="Dataset1" uuid="80437998-de38-4910-aa57-35298bd908de">
                                      <datasetParameter name="Parameter1">
                                      </datasetParameter>
                                  </datasetRun>
                                  <jr:listContents height="30" width="500">
                                      <textField isStretchWithOverflow="true" isBlankWhenNull="true">
                                          <reportElement x="0" y="0" width="500" height="30" isPrintWhenDetailOverflows="true" uuid="45491af6-5901-4f93-a248-033b3c090913">
                                          </reportElement>
                                          <textFieldExpression><![CDATA[$F{c_date} + "   " + $F{c_investigation} +"   " + $F{c_value}]]></textFieldExpression>
                                      </textField>
                                  </jr:listContents>
                              </jr:list>
                          </componentElement>
                          <componentElement>
                              <reportElement key="" style="Title" x="0" y="370" width="500" height="90" isPrintWhenDetailOverflows="true" uuid="e3bd1a29-9716-4a2b-82aa-2674f7ee86e5">
                                  <property name="net.sf.jasperreports.export.headertoolbar.table.name" value=""/>
                              </reportElement>
                              <jr:table xmlns:jr="http://jasperreports.sourceforge.net/jasperreports/components" xsi:schemaLocation="http://jasperreports.sourceforge.net/jasperreports/components http://jasperreports.sourceforge.net/xsd/components.xsd" whenNoDataType="Blank">
                                  <datasetRun subDataset="Dataset3" uuid="75312644-371c-4a4f-9714-21b41331f3d9">
                                      <datasetParameter name="Parameter5">
                                      </datasetParameter>
                                  </datasetRun>
                                  <jr:column width="170" uuid="3ba9cbcc-047d-4399-afbb-b123ac7fa1ed">
                                      <property name="com.jaspersoft.studio.components.table.model.column.name" value="Column1"/>
                                      <jr:columnHeader height="30" rowSpan="1">
                                          <staticText>
                                              <reportElement key="" style="Column header" stretchType="RelativeToTallestObject" x="0" y="0" width="130" height="30" forecolor="#000000" uuid="b1af2bb2-531d-4bb3-aa7f-1d5de582564b">
                                              </reportElement>
                                              <box leftPadding="2"/>
                                              <textElement>
                                                  <font fontName="DejaVu Sans" size="12" isBold="true"/>
                                              </textElement>
                                              <text><![CDATA[Medicine]]></text>
                                          </staticText>
                                      </jr:columnHeader>
                                          <textField>
                                              <reportElement style="Detail" stretchType="RelativeToBandHeight" x="0" y="0" width="130" height="30" uuid="9683c83b-9b87-463f-9f95-a151d5404c37"/>
                                              <textElement>
                                                  <font fontName="DejaVu Sans" size="12"/>
                                              </textElement>
                                              <textFieldExpression><![CDATA[$F{c_drug}]]></textFieldExpression>
                                          </textField>
                                      </jr:detailCell>
                                  </jr:column>
                                  <jr:column width="170" uuid="305d3d04-4947-4b13-b7e8-22d6a5d7674f">
                                      <property name="com.jaspersoft.studio.components.table.model.column.name" value="Column2"/>
                                          <staticText>
                                              <reportElement stretchType="RelativeToBandHeight" x="0" y="0" width="130" height="30" uuid="311e57e0-ddbf-4857-b67d-6bfc6b58054b">
                                              </reportElement>
                                              <textElement>
                                              </textElement>
                                              <text><![CDATA[Method]]></text>
                                          </staticText>
                                      </jr:columnHeader>
                                          <textField>
                                              <reportElement stretchType="RelativeToBandHeight" x="0" y="0" width="130" height="30" uuid="8c5a6716-5b5e-4efe-b802-b30ca1f1f921">
                                              </reportElement>
                                              <textElement>
                                              </textElement>
                                              <textFieldExpression><![CDATA[$F{c_method}]]></textFieldExpression>
                                          </textField>
                                      </jr:detailCell>
                                  </jr:column>
                                  <jr:column width="160" uuid="11c9a1db-f6c0-4916-b0e5-d03652c0e40c">
                                      <property name="com.jaspersoft.studio.components.table.model.column.name" value="Column3"/>
                                          <staticText>
                                              <reportElement stretchType="RelativeToBandHeight" x="0" y="0" width="120" height="30" uuid="9f05d11d-063f-4c4e-87dc-4829b486d542">
                                              </reportElement>
                                              <textElement>
                                              </textElement>
                                              <text><![CDATA[Times]]></text>
                                          </staticText>
                                      </jr:columnHeader>
                                          <textField>
                                              <reportElement stretchType="RelativeToBandHeight" x="0" y="0" width="120" height="30" uuid="17c1b905-1d54-4c70-b26f-2115bba1de7a">
                                              </reportElement>
                                              <textElement>
                                              </textElement>
                                              <textFieldExpression><![CDATA[$F{c_frequency}]]></textFieldExpression>
                                          </textField>
                                      </jr:detailCell>
                                  </jr:column>
                              </jr:table>
                          </componentElement>
                          <line>
                              <reportElement x="0" y="56" width="557" height="1" uuid="dd052bfe-9282-4129-b9ba-41778add49fb"/>
                          </line>
                      </band>
                  </title>
                  <lastPageFooter>
                      <band height="140">
                          <componentElement>
                              <reportElement style="Column header" isPrintRepeatedValues="false" x="0" y="0" width="556" height="120" isRemoveLineWhenBlank="true" isPrintWhenDetailOverflows="true" uuid="6bfa381b-dc5c-42c4-95c8-5f12117a7dd6">
                              </reportElement>
                                  <datasetRun subDataset="Dataset4" uuid="80437998-de38-4910-aa57-35298bd908de">
                                      <datasetParameter name="doctors_name">
                                          <datasetParameterExpression><![CDATA[$P{doctors_name}]]></datasetParameterExpression>
                                      </datasetParameter>
                                  </datasetRun>
                                  <jr:listContents height="120" width="556">
                                          <reportElement x="0" y="0" width="275" height="15" isPrintWhenDetailOverflows="true" uuid="45491af6-5901-4f93-a248-033b3c090913">
                                          </reportElement>
                                          <textFieldExpression><![CDATA[$F{c_degree1} + "   " + $F{c_degree2} +"   " + $F{c_degree3} + " " + $F{c_docRegisteration}]]></textFieldExpression>
                                      </textField>
                                          <reportElement x="277" y="0" width="275" height="14" isPrintWhenDetailOverflows="true" uuid="45491af6-5901-4f93-a248-033b3c090913">
                                          </reportElement>
                                          <textFieldExpression><![CDATA[$F{c_emailId} + "   " + $F{c_phoneNumber2} +"   " + $F{c_phoneNumber}]]></textFieldExpression>
                                      </textField>
                                          <reportElement x="0" y="31" width="275" height="40" isPrintWhenDetailOverflows="true" uuid="45491af6-5901-4f93-a248-033b3c090913">
                                          </reportElement>
                                          <textFieldExpression><![CDATA[$F{c_opd1}]]></textFieldExpression>
                                      </textField>
                                          <reportElement x="277" y="31" width="275" height="40" isPrintWhenDetailOverflows="true" uuid="45491af6-5901-4f93-a248-033b3c090913">
                                          </reportElement>
                                          <textFieldExpression><![CDATA[$F{c_opd2}]]></textFieldExpression>
                                      </textField>
                                  </jr:listContents>
                              </jr:list>
                          </componentElement>
                          <staticText>
                              <reportElement mode="Opaque" x="-1" y="72" width="556" height="20" backcolor="#E6E8E9" uuid="36aa233d-4305-48e6-974a-1bbf89bb3c8f"/>
                              <textElement textAlignment="Center" verticalAlignment="Middle">
                                  <font fontName="Serif" size="9" isItalic="true"/>
                              </textElement>
                              <text><![CDATA[THANKYOU FOR COMING, GET WELL SOON]]></text>
                          </staticText>
                      </band>
                  </lastPageFooter>
              </jasperReport>
                Hi, perhaps you can try reducing your band height value? I had a similar problem resolved by doing that. In any case, you could also share a sample JRXML to demonstrate your issue.
