I have followed the example for creating an autocomplete text field from the Knowledge Base for v5. It does not work. Any suggestions? Specifically, I want to autocomplete against a specific column in a table in our database.
Thanks,
Joel
      Hi, which example do you mean, and what errors did you encounter? You can try using other form elements like the Multi Select Box or Popup Select Box for something like this.
        There is an example in the Knowledge Base for v5 documentation. There is no Multi Select Box or Popup Select Box form elements available. I am not using the Enterprise version. So, perhaps, that is why they do not show up.
