If I have selected box contains Month (January to December) using jdbc binder, how do I control to select only 3 month before included current month? Means, only allow to select October (current Month), September and August.
      Hi Andrew,
      Thanks!. It works..
        Hi Rosadilla
        In your Selectbox SQL query in JDBC Binder, you can use the Date Hash Variable #date.M# to return the current system month and add this into your SQL WHERE clause. You can also use the #date.MONTH-x.M# syntax to perform some simple calculation.
        For example, assuming you stored your months lookup records in table "app_fd_yearsetup" as follows:
        c_number     c_month
        8                   Aug
        9                   Sep
        10                 Oct
        This example SQL will filter to show only Aug, Sep and Oct in your selectbox.
        SELECT c_number,
               c_month
        FROM   app_fd_yearsetup
        WHERE  (c_number = '#date.MONTH-2.M#'
                OR c_number = '#date.MONTH-1.M#'
                OR c_number = '#date.M#' )
        Hope this helps.
