Dear Expert,
I have a landing page which contains all the apps. Upon login, it will direct the user to the landing page. And, user need to select the app which he/she would like to launch.
Below is my scenarios :
1) Upon submitting a form, approver receives an email(I'm using my own plugin as we need different the user's domain).
2) The link is given in the email (eg    #request.scheme#://#request.serverName##request.contextPath#/web /userview/#requestParam.appId#/#requestParam.userviewId#/_/approver_inbox)
2) When approver clicks on the link, it brings the approver to the landing page.
My Question :
How do I customize the url to 'approver_inbox' directly instead of landing page ?
      Hello,
      I have the same question as Shubana.  We also have the SAML plugin installed and would like to be able to direct users to specific destinations rather than a single pre-configured location.  Is there a built-in way to do this with the current plugin?
      Hypothetical example of what I'm imaginging: https://my-adfs.biz/login?app=https://my-joget.biz/jw/web/json/plugin/org.joget.plugin.saml.SamlDirectoryManager/service?redirect=%2Fjw%2Fweb%2Fuserview%2FMy-APP%2Fv%2F_%2FMy-App-crud
      where "redirect=" points to the final page destination.
      Thanks,
      John
        Hi Andrew,
        Thank you for highlighting on the requestParam do and dont's in email tool.
        I am unable to use user notification because I have SAML authentication.
        Is there any other way to direct the SAML users directly to the app instead of directing them to the landing page.
          You can use this URL string in your email:
          #request.scheme#://#request.serverName#:#request.serverPort##request.contextPath#/web/userview/appId/userviewId/_/approver_inbox .
          You have to hardcode the "appId", "userviewId" and menu id "approver_inbox", unless you store these string value in your app (like a app setup form save with id='1') which you can then reference using these method:
          #form.setup.appId[1]#
          or use an environment variable to store the appId:
          #envVariable.appId#
          You won't be able to use #requestParam# in an email tool because the tool runs in the background and has no access to the browser's url. #requestParam# are mostly used on front facing forms running in a browser (interactive).
          Do try out the User Notification plugin which will send and email to the assignee and auto insert the link for his task.
          Reference: https://dev.joget.org/community/display/KBv5/Hash+Variable#HashVariable-RequestParameterHashVariable
