Hello,
I have a requirement as attached sample App shows:
When use "process" hyperlink start another workflow, I want to copy record this line into process related table "t01_form1". And it should be one2many(different id in table "t01_form1").
can you help me?
thank you
APP_testprocess-1-20180109123422.jwa
  1. Andrew
    Your question is not clear. Table "t01_form1" already contains the process data. Kindly elaborate in more details. Thank you.
    Hi, the question is not clear, perhaps you could provide more detailed examples of what is expected?
