I have the same problem.
Could you tell me if you have found a solution?
Thank you
Hi, you can try using the Default Form Options Binder, or any of the options binder that suits your needs.
Hi, Thank you for your quick reply, But as i mentioned in question JASPER report is used in USERVIEW not in form. My requirement is to fetch data from database in custom HTML. Default Form Options Binder can be only used in forms.
I am using JASPER report in userview and i have added custom dropdown for data filtering.
I achieved this using this sample
Now i need to bind data from database to my dropdown.
How can i achieve this?
