The Joget Web API doesn't handle error properly. Take start-process endpoint for example:
- Start a process with "Logged In User" start process whitelist
POST http://10.1.12.224:8080/jw/web/json/workflow/process/start/app-name:latest:process-name
Response: 200 OK {"activityId":"","processId":""}
Expected response: 403 FORBIDDEN
- Request a wrong process name
POST http://10.1.12.224:8080/jw/web/json/workflow/process/start/app-name:latest:wrong-process-name
Expected response: 404 NOT FOUND
Is it possible to modify Joget web API to handle errors properly?
      Hi, I do not know about modifying the API unless you wish to change the source code directly, but based on the existing behavior you could handle the response by checking  the values of the processId and/or activityId.
