Hello team. I need help with a little bit of urgency. I was trying to internationalize Joget. I correctly imported the PO files available at the moment for the Spanish language (I even contributed in the translation of some) and changed the default language of the application.
Now many of the formats in the console are being incorrectly applied and I can not reverse the change, since it shows me the pop-ups of the application without formats. Does anyone know how to do the rollback and go back to the ENG configuration through the database?
      I realized how to fix it. It is only necessary to modify the information of the "systemLocale" parameter in the wf_setup table by "en_US". I will be working hard on the translation through the project https://translate.joget.org/ since this is a priority need.
