Dear all,
I have requirement to integrate joget internal user and external user (ldap). I have configure Security Enhanced Directory Manager and load both internal and external user. I have no permission in client's Active Directory to configure Departement in LDAP OU.
I have problem on
* configure Userview Permission with multiple user/group in cross Organization (local and external ldap). It only allow user/group in same Organization unit.
* Hardcoded in Process / Map Participants to user
Can I configure new Joget's Organization to assign both local user and external user? Thus I can configure Userview permission and Map Participant to this Group (with local and external user).
I'm using Joget Workflow v5.
Regards,
Syafri
      Dear all,
      I have the solution by create new table as a bridge and register both local and ldap user.
      Then configure
      * Userview permission Type to "Bean shell Script", and add code to load user from those bridge table.
      * "Map Participants to Users" to "Map to Plugin Bean Shell Tool", and add code to load user from those bridge table.
      Regards,
      Syafri
        Hi, you could try mapping the participant to a custom plugin, or perhaps beanshell like in Bean Shell Programming Guide#UseasProcessParticipant
          As far as I know, we can't do it. This is because they are essentially 2 separate, distinctive user directory.
