Joget DX Preview Release Available for Download
hi,
am getting below error, all tables are created as per the manual..
INFO  15 May 2018 17:07:09 org.joget.commons.util.SetupManager  - Initializing setup cache
INFO  15 May 2018 17:07:09 org.joget.plugin.base.PluginManager  - PluginManager initialized
ERROR 15 May 2018 17:07:11 org.hibernate.engine.jdbc.spi.SqlExceptionHelper  - ORA-00942: table or view does not exist
INFO  15 May 2018 17:07:12 org.joget.workflow.model.service.WorkflowManagerImpl  - Datasource bound to jwdb
SharkEngineManager -> Shark engine is being initialized ...
2018-05-15 17:07:13,063:  <SqlQueryExecute><SqlQueryException>(<Replicated>:ORA-00942: table or view does not exist
2018-05-15 17:07:13,064:  <SqlQueryExecute><SqlQueryException>(<Replicated>:ORA-00942: table or view does not exist
com.lutris.dods.builder.generator.query.DataObjectException: Unknown SQLException: <SqlQueryExecute><SqlQueryException>(<Replicated>:ORA-00942: table or view does not exist
        at org.enhydra.shark.instancepersistence.data.ProcessStateQuery._runQuery(ProcessStateQuery.java:1181)
        at org.enhydra.shark.instancepersistence.data.ProcessStateQuery.runQuery(ProcessStateQuery.java:632)
        at org.enhydra.shark.instancepersistence.data.ProcessStateQuery.getNextDO(ProcessStateQuery.java:1406)
        at org.enhydra.shark.instancepersistence.data.ProcessStateDO.__refreshCache(ProcessStateDO.java:862)
        at org.enhydra.shark.instancepersistence.data.ProcessStateDO.refreshCache(ProcessStateDO.java:769)
        at org.enhydra.shark.instancepersistence.DODSPersistentManager.refreshDOCaches(DODSPersistentManager.java:4668)
        at org.enhydra.shark.instancepersistence.DODSPersistentManager.setLDBName(DODSPersistentManager.java:4642)
        at org.enhydra.shark.instancepersistence.DODSPersistentManager.initActivityAndProcessStatesTable(DODSPersistentManager.java:226)
        at org.enhydra.shark.instancepersistence.DODSPersistentManager.configure(DODSPersistentManager.java:191)
        at org.enhydra.shark.SharkEngineManager.init(SharkEngineManager.java:266)
        at org.enhydra.shark.SharkEngineManager.init(SharkEngineManager.java:872)
        at org.enhydra.shark.SharkEngineManager.configure(SharkEngineManager.java:535)
        at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
        at org.enhydra.shark.Shark._conf(Shark.java:127)
        at org.enhydra.shark.Shark.configure(Shark.java:54)
        at org.joget.workflow.shark.JSPClientUtilities.init(JSPClientUtilities.java:115)
        at org.joget.workflow.model.service.WorkflowManagerImpl$2.doInTransactionWithoutResult(WorkflowManagerImpl.java:204)
        at org.springframework.transaction.support.TransactionCallbackWithoutResult.doInTransaction(TransactionCallbackWithoutResult.java:34)
        at org.springframework.transaction.support.TransactionTemplate.execute(TransactionTemplate.java:133)
        at org.joget.workflow.model.service.WorkflowManagerImpl.setPath(WorkflowManagerImpl.java:200)
        at org.joget.workflow.model.service.WorkflowManagerImpl.<init>(WorkflowManagerImpl.java:140)
        at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
        at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62)
        at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
        at java.lang.reflect.Constructor.newInstance(Constructor.java:423)
        at org.springframework.beans.BeanUtils.instantiateClass(BeanUtils.java:142)
        at org.springframework.beans.factory.support.SimpleInstantiationStrategy.instantiate(SimpleInstantiationStrategy.java:122)
        at org.springframework.beans.factory.support.ConstructorResolver.autowireConstructor(ConstructorResolver.java:271)
        at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.autowireConstructor(AbstractAutowireCapableBeanFactory.java:1148)
        at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:1051)
        at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:510)
        at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:482)
        at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:306)
        at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:230)
        at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:302)
        at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:197)
        at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:751)
        at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:861)
        at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:541)
        at org.springframework.web.context.ContextLoader.configureAndRefreshWebApplicationContext(ContextLoader.java:444)
        at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:326)
        at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:107)
        at org.joget.commons.spring.web.CustomContextLoaderListener.contextInitialized(CustomContextLoaderListener.java:31)
        at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4745)
        at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5207)
        at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:150)
        at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:752)
        at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:728)
        at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:734)
        at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:988)
        at org.apache.catalina.startup.HostConfig$DeployWar.run(HostConfig.java:1860)
        at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
        at java.util.concurrent.FutureTask.run(FutureTask.java:266)
        at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
        at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
        at java.lang.Thread.run(Thread.java:745)
Caused by: java.sql.SQLException: <SqlQueryExecute><SqlQueryException>(<Replicated>:ORA-00942: table or view does not exist
        at com.lutris.dods.builder.generator.query.QueryBuilder.executeQuery(QueryBuilder.java:2522)
        at org.enhydra.shark.instancepersistence.data.ProcessStateQuery.executeQuery(ProcessStateQuery.java:1592)
        at com.lutris.appserver.server.sql.standard.StandardDBQuery.query(StandardDBQuery.java:118)
        at org.enhydra.shark.instancepersistence.data.ProcessStateQuery._runQuery(ProcessStateQuery.java:904)
        ... 58 more
*** Caused by:
*** Caused by:
2018-05-15 17:07:13,132:  <SqlQueryExecute><SqlQueryException>(<Replicated>:ORA-00942: table or view does not exist
      Hi, the error "ORA-00942: table or view does not exist" indicates some required tables do not exist. Did you create the database and verify that the tables exist correctly according to the steps in Configure for Oracle 18c, 12c, 11g, 10g?
      1. prasa
        Hi thanks for your reply as per manual i have created all the table without any errors in jwdb schema using the file "jwdb-oracle.sql" . but getting this error msg.
