i found some bug about dependency input.
section 1 display by default have 2 input
  • radio
  • selectbox with radio dependency relation
section 2 when show hide section 1
if
  1. select radio and value in selectbox
  2. change value in visible to 2
  3. change value in visible to 3
  4. you can seem selectbox is lost focus
sample form JSON Definition
{"className":"org.joget.apps.form.model.Form","properties":{"id":"dependencyBug","loadBinder":{"className":"org.joget.apps.form.lib.WorkflowFormBinder","properties":{}},"description":"","tableName":"prototypes","postProcessorRunOn":"both","name":"Dependency Bug","postProcessor":{"className":"","properties":{}},"storeBinder":{"className":"org.joget.apps.form.lib.WorkflowFormBinder","properties":{}},"permission":{"className":"","properties":{}},"noPermissionMessage":""},"elements":[{"elements":[{"elements":[{"className":"org.joget.apps.form.lib.TextField","properties":{"id":"visible","workflowVariable":"","readonlyLabel":"","maxlength":"","encryption":"","validator":{"className":"","properties":{}},"value":"","label":"visible","readonly":"","size":""}}],"className":"org.joget.apps.form.model.Column","properties":{"width":"100%"}}],"className":"org.joget.apps.form.model.Section","properties":{"id":"section1","loadBinder":{"className":"","properties":{}},"visibilityControl":"","regex":"","visibilityValue":"","storeBinder":{"className":"","properties":{}},"label":"Section","permission":{"className":"","properties":{}}}},{"elements":[{"elements":[{"className":"org.joget.apps.form.lib.Radio","properties":{"id":"dayType","readonlyLabel":"","workflowVariable":"","optionsBinder":{"className":"","properties":{}},"validator":{"className":"","properties":{}},"value":"","controlField":"","label":"Day Type","readonly":"","options":[{"grouping":"","value":"workday","label":"Workday"},{"grouping":"","value":"weekend","label":"Weekend"}]}},{"className":"org.joget.plugin.enterprise.MultiSelectBox","properties":{"id":"DayOfWeek","readonlyLabel":"","workflowVariable":"","optionsBinder":{"className":"","properties":{}},"validator":{"className":"","properties":{}},"value":"","controlField":"dayType","label":"Day Of Week","multiple":"","readonly":"","options":[{"grouping":"workday","value":"monday","label":"Monday"},{"grouping":"workday","value":"tuesday","label":"Tuesday"},{"grouping":"workday","value":"wednesday","label":"Wednesday"},{"grouping":"workday","value":"thursday","label":"Thursday"},{"grouping":"workday","value":"friday","label":"Friday"},{"grouping":"weekend","value":"saturday","label":"Saturday"},{"grouping":"weekend","value":"sunday","label":"Sunday"}],"size":""}}],"className":"org.joget.apps.form.model.Column","properties":{"width":"100%"}}],"className":"org.joget.apps.form.model.Section","properties":{"id":"section2","loadBinder":{"className":"","properties":{}},"visibilityControl":"visible","regex":"","visibilityValue":"1","storeBinder":{"className":"","properties":{}},"label":"Section 2 visible = 1","permission":{"className":"","properties":{}}}},{"elements":[{"elements":[],"className":"org.joget.apps.form.model.Column","properties":{"width":"100%"}}],"className":"org.joget.apps.form.model.Section","properties":{"id":"section3","loadBinder":{"className":"","properties":{}},"visibilityControl":"visible","regex":"","visibilityValue":"2","storeBinder":{"className":"","properties":{}},"label":"Section 3 visible = 2","permission":{"className":"","properties":{}}}}]}
regard
pitt phunsanit
  1. Hugo
    Thank you for reporting this. We will look into this.
    Thank you for reporting this issue. The issue has been fixed and will be available in the next build version.
    Thank you.
