hi
how to store Arabic text in database from a text box (get from Joget form), because a validation error comes. i don't change all language on the form, please
      Problem resolved by changing the Database Charter set for latin1 to utf8 and also change the Table and column
      now the create table script is some thing like that
      CREATE TABLE `app_fd_video_New` (
      `id` varchar(255) COLLATE utf8_unicode_ci NOT NULL,
      `c_field1` longtext COLLATE utf8_unicode_ci,
      `c_field2` longtext COLLATE utf8_unicode_ci,
      PRIMARY KEY (`id`)
      ) ENGINE=InnoDB DEFAULT CHARSET=utf8 COLLATE=utf8_unicode_ci
      Regards,
        Sir its error in log
        ERROR 02 Jul 2018 12:08:13 org.hibernate.engine.jdbc.spi.SqlExceptionHelper - (conn:118) Incorrect string value: '\xD9\x83\xD8\xA3\xD8\xB3...' for column 'c_field1' at row 1
        ERROR 02 Jul 2018 12:08:13 org.joget.apps.form.service.FormService - Error executing store binder
        org.hibernate.exception.GenericJDBCException: could not execute statement
        at org.hibernate.exception.internal.StandardSQLExceptionConverter.convert(StandardSQLExceptionConverter.java:54)
        at org.hibernate.engine.jdbc.spi.SqlExceptionHelper.convert(SqlExceptionHelper.java:126)
        at org.hibernate.engine.jdbc.spi.SqlExceptionHelper.convert(SqlExceptionHelper.java:112)
        at org.hibernate.engine.jdbc.internal.ResultSetReturnImpl.executeUpdate(ResultSetReturnImpl.java:211)
        at org.hibernate.engine.jdbc.batch.internal.NonBatchingBatch.addToBatch(NonBatchingBatch.java:62)
        at org.hibernate.persister.entity.AbstractEntityPersister.insert(AbstractEntityPersister.java:3124)
        at org.hibernate.persister.entity.AbstractEntityPersister.insert(AbstractEntityPersister.java:3581)
        and in the last
        Caused by: java.sql.SQLException: Incorrect string value: '\xD9\x83\xD8\xA3\xD8\xB3...' for column 'c_field1' at row 1
        Query is: insert into app_fd_video_New (dateCreated, dateModified, createdBy, createdByName, modifiedBy, modifiedByName, c_field1, c_field2, id) values (?, ?, ?, ?, ?, ?, ?, ?, ?), parameters ['2018-07-02 12:08:13.67','2018-07-02 12:08:13.67','admin','Admin Admin','admin','Admin Admin','كأس العالم: اليوم في الكلمات: يوم 17','fdgdf','59d205e5-7f001010-1c028fdb-9c1f6f87']
        at org.mariadb.jdbc.internal.util.LogQueryTool.exceptionWithQuery(LogQueryTool.java:146)
        at org.mariadb.jdbc.internal.protocol.AbstractQueryProtocol.executeQuery(AbstractQueryProtocol.java:215)
        at org.mariadb.jdbc.MariaDbPreparedStatementClient.executeInternal_aroundBody6(MariaDbPreparedStatementClient.java:212)
        ... 227 more
          I just tested and managed to store Arabic text using Text Area in Joget form, with the default system locale. Did you see any error in tomcat log?
