is it possible to use hashvariables in the Hyperlink field in datalist?
      Hi, it is not possible as the form hash variable need the primary key passing form url or workflow assignment. But, in datalist, the primary key is not available in neither url or workflow assignment.
      You only can use the "Hyperlink Parameters" to populate your value.
