In Request param comma added for select box value while used as redirect url
xxx?month=#requestParam.month#&year=#requestParam.year#
Here month and year are select box. on redirect it showing like month=January, January, &year=2017, 2017, in url
      Hi, I not sure how your value store. But, there is URL escape syntax for hash variable. You can check Hash Variable#EscapingtheResultantHashVariable.
      1. Ranjith
        This happens due to two fields with same id in form.Thanks for the response
