    Hey Sohail,
    If you meant that you want end users to only be able to select one option only from multiple choices of checkboxes, we suggest you use Radio Buttons instead.
    All the best!
      Hi, can you explain in more detail what you wish to achieve? I can't understand what is meant by select one check box at a time.
