Am using form grid to save data. But only id is save. Only after submitting parrent form only data saved.
But i need to save all data.
Please help
      Hi Ranjith
      Develop a form e.g. images_frm and its linked with db table app_fd_image_frm, now when you use Form grid on any other form(main_frm) and linked that grid with image_frm, try to consider those points
      1- mention image_frm in FORM Option
      2- linked your image_frm fields with COLUMN list
      3- in DATA Binder select Multirow Form Binder in both LOAD & STORE options
      4- in relevant options you select image_frm in FORM and assign Foreign Key in both SOTRE & LOAD
      now when you select edit option of any entry in displayed Form Grid rows a popup will appear with image_frm and if you change any option in that form and Submit and then submit the you main form(main_frm) the changes you made in image_frm will be updated in relevant table(app_fd_image_frm).
      Regards,
      1. Ranjith
        Thanks for the clear explanation. "Submit and then submit the you main form(main_frm) " - So only after clicking main form submit image_frm form data will be save to table right?
      Hi please, any suggestion?
        I have a form which holds form grid Mapped to another form(new table). When i submit the Grid Forms form, the only id is saved. Only after clicking the main forms submit button, other fields get updated.
          Hey there,
          I don't understand the question. Is it possible to take screenshots and annotate it for clarification?
          Thanks.
          1. Ranjith
            Thanks, I have a form which holds form grid Mapped to another form(new table). When i submit the Grid Forms form, the only id is saved. Only after clicking the main forms submit button, other fields get updated.
