I am using Joget V6 community version.
My requirement is to add/remove text fields dynamically .
So i have used custom HTML and used following code. But it is not saving to database.
Could anyone help me on this.
<div class="container1">
<button class="add_form_field">Add New Field &nbsp; <span style="font-size:16px; font-weight:bold;">+ </span></button>
<div><input type="text" name="mytext[]"></div>
</div>
And in another custom HTML i have used javascript
        var max_fields      = 10;
        var wrapper         = $(".container1");
        var add_button      = $(".add_form_field");
        var x = 1;
        $(add_button).click(function(e){
            e.preventDefault();
            if(x < max_fields){
                x++;
                $(wrapper).append('<div><input type="text" name="mytext[]"/><a href="#" class="delete">Delete</a></div>'); //add input box
      else
      alert('You Reached the limits')
        $(wrapper).on("click",".delete", function(e){
            e.preventDefault(); $(this).parent('div').remove(); x--;
    </script>
But this is creating fields properly and upon submitting it is showing as "Form submitted' But table is not created
      Hey gb,
      Try using a JDBC binder as your store binder to handle storage of new fields in your Form.
      1. gb
        Thank you..
