Hello,
I have a problem in retrieving workflow variable from the submitted form to use in Database Update Tool query. In my scenario, I have a process which after I submit a form, if approvalStatus == 'Verified', Database will be updated. I want to take the value of approvalStatus to save in updating db.
I try using this #variable.approvalStatus# but got error : Invalid column name 'Verified'
      Hi, since the error says Invalid column name 'Verified', I believe the #variable.approvalStatus# hash variable is returning the correct value. Please ensure that you are using the hash variable correctly in your Database Update Tool SQL query.
