Hi, are you using the Community Edition? The marketplace page specifies that it is designed for the Enterprise Edition.
Ohh my, yeah, it's my mistake, I didn't realise it, I didn't read the instruction. I was import it on Community Edition instead of Enterprise Edition. It's all good now, thanks
Hi May I know what database are you using? Do also have a look at ..\apache-tomcat-8.5.23\logs\joget.log to see if there are any errors. I tested on MySQL and Joget Workflow Processional v6 (Windows) and the app is working well. Thank you.
Hi, sorry for late reply I'm quite beginner, so i don't really know what database I'm using through Joget but I presume it a default because before this I was using Xampp for others purpose, so when I first installed Joget, it has problem with Xampp, after I uninstall Xampp, Joget App Center directly go to main interfaces without go through here https://dev.joget.org/community/display/KBv6/Setting+Up+Database And I do look at ..\apache-tomcat-8.5.23\logs\joget.log but no error to be found even though i refresh and do the same interaction again
