Before this, I try use json api from external form but the form is still in joget workflow base url which is "http://localhost:8080/jw/" . But I want to integrate external form from external base url with joget workflow process. I try using "http://localhost/" but I get 404 not found in return.
      Sure, your external page can be hosted in any env. ( Intranet or Public host) but needs access to the Joget Workflow Server and port to run your Page and trigger your process.
      Rgds,
        Hi, I do not understand the question. What is supposed to be running at http://localhost?
        1. NFMJ
          I try to triggered joget workflow process from external form. Before this, I use https://dev.joget.org/community/display/KBv5/Start+a+Process+from+External+Page but it is in joget workflow env and using base url "http://localhost:8080/jw/";. But what if the external form is not using in joget workflow env and using other base url? can the integration still working?
