Why i cannot adjust width of each column ? although i alrady did in each setting column.?
  1. abdul Fattah
    and one more question. I cannot do total of all rental/month and display at bottm?
  2. Justin
    Perhaps you can try editing the list userview element, and writing javascript into the 'custom header/footer' configuration field.
    From the photo attached, the large number of columns has utilized the maximum screen estate of your device, and hence already at the maximum possible width. Adjusting to a higher width value will not take effect.
      The free Tutorial App: Datalist in Joget Marketplace has examples on how to change the look and feel of the datalist, including adding totals etc.
