We found the partial answer: It is indeed an administration error that has to do with the "Delete Process On Completion" parameter. this parameter does not distinguish by process and applies to all those that are being completed. It was activated by a configuration error. It would be ideal if the processes for which it applies could be chosen!
Hi, perhaps a user with administrator access deleted the process instance? You can check the Audit Trail to see if any processes are removed.
When you update your process diagram, all the ID's are updated in shkprocesses and shkactivities tables so if you want to link you old activities you can use wf_process_link table,
its a sample query
SELECT d.*, Group_concat(a.NAME) AS 'current_activities' FROM app_fd_hr_tableName d LEFT JOIN wf_process_link pl ON d.id = pl.originprocessid LEFT JOIN shkactivities a ON a.state IN ( 1000001, 1000003, 1000005 ) AND ( a.processid = d.id OR a.processid = pl.processid )
hope it will help you
Regards,
Farhan
Hello, we usually took the information from the shkprocesses and shkactivities tables to monitor the times of the activities carried out in a particular process. However, for some of the processes executed, for some reason we did not find the trace in these tables, as if the process had never existed. However, if there is evidence of execution in the different data tables.
Is there any reason why this information is not recorded? Is there any parameter that causes this information to be deleted?
Your help please! Is there a way to contact an official Joget support to verify this issue?
