I succeeded to build following the guide.
https://dev.joget.org/community/display/KBv6/Joget+Workflow+Open+Source
how can I run 'workflow' when the build succeeds?
I want to make sure that I did it right.
      Hi, what do you mean by run 'workflow'? I am assuming that you want to run the webapp. After the build would have a Java WAR web archive jw.war file in the target directory in wflow-consoleweb. You can deploy that WAR file to your app server. If you are using Apache Tomcat then you can just copy the WAR into the webapps directory.
      1. leka2002
        it works. thanks.
