I installed the Purchase Request App from the marketplace. In the PR List page, beside the "New Purchase Request", there is also a "New" button, which is duplicate and does not start the workflow properly, so I want to hide it. How do I do it?
Thank you.
      You can edit the Userview "PR Listing" menu properties and remove the "Form (Add)" selection to remove the "New" button from displaying in your app. Example screenshow below"
      Hope this helps.
      Thank you.
        Thank you. I've tried both this and the runProcess properties, it did not change the label. Maybe there is something I missed?
          I saw your question and this might help you.
          In Userview Builder, CRUD properties, just click the "Show Delete Button?" checkbox.
          In the same properties screen, to change the button labels, just key in your text in the properties field "Save Button Label".
          Cheers
            thank you Andrew. That worked.
            I am now trying to have the "Delete" button to show up (on the UI List page), but it is not showing up, where should I look?
            Also, I want to change a few form submissions in the workflow from "Complete" to "Next", how do I do that?
            Thank you in advance.
