Hi, from the article it is a normal app so yes you can import it into your joget installation and then make any changes as you need.
found a thread "Merge 2+ processes into 1 datalist inbox [Multiapproval application]"
for exactly what I was looking for, but having some hard time to make it work.
Has anyone worked on something like this?
for some reason the app in the example had a beanshell tool mapped to the administrator, as soon as I removed the plugin it worked as I expected...
Is there a reason the approval inbox is setup without a datalist attached to it? I tried to create a datalist for the Approve process but nothing is showing up even when Monitor->Running Process shows there are Approve process generated...
I am also trying to embed this into my overall process. I have got almost everything working, the problem I have, other than what was described above, is that as soon as I enter this flow (I removed the Apply activity, replaced with my own step), the process disappears from my datalist inbox. However if I log out of the app, click on the inbox, it shows up as a process staying at WaitingForReponse step. What would cause this?
Thank you in advance.
Hi, in the app, after the Apply is run, the app only shows a simple "Assignment updated" screen. I'd like to connect a Form with the Waiting For Response activity and show that form, how do I achieve it?
Thank you.
can I customize 'Multiple Approval' ?
https://dev.joget.org/community/display/KBv6/Multiple+Approval
can I modify source code ?
If it is not possible, can I make it the same?
