I want to add the ability to edit an approved submission, once edited, the form would go to a new revision level, then run another round of approval process, how do I achieve this?
Thank you.
      Hi Anders,
      Thank you for the suggestion. I've tried it, the problem that I am running into in this case is that I will be only running a part of the process, therefore I need to be able to have another "start" process, which the system doesn't seem to allow me to do.
      Am I correct that there can be only one "start" in the process?
        Hi, perhaps you can try referring to Start Process from Datalist Hyperlink Action to see if it meets your requirement.
