as default process id is set as primary key, if we change the primary key,it is possible?where we can change it?
      Joget, needs the process id as primary key o edit the register but if you need to change it in order to get another kind of process done, Joget lets you do it.
      1. abdul Fattah
        how we can change it? cause want i chanege in databse it also popup an error
      2. Kurt Cobain
        How? And can we create 2 primary keys?
      I think we will need a bit more context on this. I assume that you are starting a process from a joget form. In your Joget form, add a field, and set the ID to "id". Joget will then use the "id" value you set as the primary key.
      1. abdul Fattah
        i already did that and the error popup when i click submit button. "Error storing data: could not execute statement"
      2. Walter
        Can you put your sample app here with steps to replicate?
