My scenario:
1) I run QA process, fill in main details then fill in 1st bin form
2) After complete the 1st bin, I fill in data for the 2nd bin form but I fill some of data and because it already lunch hour, I click Save As Draft button to complete the form after lunch.
3) I come back after lunch then click on the process that I left before lunch, but the data I inserted is not display.
The data save into database but when I click the process, it seems not retrieve back from the database.
      Already solved, it seems that the id to retrieve from draft and id save in database is different. That is why it cannot retrieve from previous saved data.
        Hi, did you check to verify that the data is stored in the form database table? Are there any error messages in the console or logs?
