Hello,
I have a Joget (vers 6.0.11) REST API and on GET method it doesn't decode the parameters from URL.
On your documentation I only saw encodeUrlParam:
https://dev.joget.org/community/display/KBv6/StringUtil
Please advice
  1. Walter
    What problem that you are trying to solve? Can you list down the steps?
    Are you guys technical? Do you know JAVA programming language? Do you know what GET method is?
      Hi, there is not enough information to help. Can you describe in more detail what it is that you need?
