Hai, i have facing with workflow variable when the process already run. Can i change or edit the workflow variable?
      Hi Fattah, You can using tool, add a tool in your process and at map tools to plugin add bean shell to your tool this simple code
      public void changeWV(){
                      wm.activityVariable(workflowAssignment.getActivityId(), "yourVariable", "newValue");
      return changeWV();
      good luck
      1. abdul Fattah
        it is can work is the "newValue" need to calculate first before go to that value?
      2. Muhammad Khafidz
        You can get exist value of workflow variable use hash variable #variable.yourVariable#
      3. abdul Fattah
        okay i will try it. thank you bro.
      4. abdul Fattah
        but i need to reevaluate first the process right?
