Good Morning - we are collecting data and importing it into the application table. currently it is setup to kickoff a process when the from is filled out and it works fine.  however, we are wondering if there a way to kickoff the process after inserting a row in the table such as using the import data tool or a store procedure.
Thanks - Tony
      Hi, found a few similar questions, you can start a process using the JSON API How to trigger a joget process from external website? or beanshell Start a process from bean shell tool
        found a question posted previously that i think its similar to yours:
        How can one automatically run an activity on new item from a datalist?
        Another possible option is to run it on a scheduler perhaps? There's a scheduler plugin on the Joget Marketplace: https://marketplace.joget.org/jw/web/userview/mp/mpp/_/vad?id=scheduler_v6-1
        Hope this helps.
        Cheers - Ian
