Hi Friends, please i need hurry help with this ¡
I´m needing use Bean Shell to validate if a field in the form is greatter of a value that the user write in a field (validation option) , i´m use a suggested code by expert in the forum but really i cann´t make that this  work for me, this is the code :
import java.util.Arrays;
import org.joget.apps.form.model.Form;
public boolean validate(Element element, FormData formData, String[] values) {
boolean result = true;
//get field 1 value from form data object
String field1Id = "calculo";
Form form = FormUtil.findRootForm(element);
Element field1 = FormUtil.findElement(field1Id, form, formData);
if (field1 != null) {
//get value of field 1
String[] compareValues = FormUtil.getElementPropertyValues(field1, formData);
//compare the value of field 2 and field 1 are equals
//if (!Arrays.equals(values, compareValues)) {
int inum2 = Integer.parseInt(compareValues);
if(inum2 < 100){
String id = FormUtil.getElementParameterName(element);
formData.addFormError(id, "Must be more than 1."); //change field id to your calculation field
result = false;
}else{
formData.addFormError(id, "is a number??."); //change field id to your calculation field
result = true;
return result;
//call validate method with injected variable
return validate(element, formData, values);
AND THIS IS THE Error Message that i retrive from file joget.log
ERROR 07 jun 2019 17:36:01 org.joget.apps.form.lib.BeanShellValidator - Error executing script
Sourced file: inline evaluation of: ``import java.util.Arrays; import org.joget.apps.app.service.AppUtil; import org . . . '' : Typed variable declaration : Error in method invocation: Static method parseInt( [Ljava.lang.String; ) not found in class'java.lang.Integer' : at Line: 26 : in file: inline evaluation of: ``import java.util.Arrays; import org.joget.apps.app.service.AppUtil; import org . . . '' : Integer .parseInt ( compareValues )
at bsh.BSHMethodInvocation.eval(Unknown Source)
at bsh.BSHPrimaryExpression.eval(Unknown Source)
at bsh.BSHVariableDeclarator.eval(Unknown Source)
at bsh.BSHTypedVariableDeclaration.eval(Unknown Source)
at bsh.BSHBlock.evalBlock(Unknown Source)
at bsh.BSHBlock.eval(Unknown Source)
at bsh.BSHIfStatement.eval(Unknown Source)
at bsh.BshMethod.invokeImpl(Unknown Source)
at bsh.BshMethod.invoke(Unknown Source)
at bsh.Name.invokeLocalMethod(Unknown Source)
at bsh.Name.invokeMethod(Unknown Source)
at bsh.BSHReturnStatement.eval(Unknown Source)
at bsh.Interpreter.eval(Unknown Source)
at org.joget.apps.form.lib.BeanShellValidator.executeScript_aroundBody12(BeanShellValidator.java:48)
at org.joget.apps.form.lib.BeanShellValidator.executeScript_aroundBody13$advice(BeanShellValidator.java:95)
at org.joget.apps.form.lib.BeanShellValidator.executeScript(BeanShellValidator.java:1)
at org.joget.apps.form.lib.BeanShellValidator.validate_aroundBody16(BeanShellValidator.java:70)
at org.joget.apps.form.lib.BeanShellValidator.validate_aroundBody17$advice(BeanShellValidator.java:95)
at org.joget.apps.form.lib.BeanShellValidator.validate(BeanShellValidator.java:1)
at org.joget.apps.form.service.FormUtil.executeValidators(FormUtil.java:459)
at org.joget.apps.form.service.FormUtil.executeValidators(FormUtil.java:466)
at org.joget.apps.form.service.FormServiceImpl.validateFormData(FormServiceImpl.java:312)
at org.joget.apps.form.service.FormServiceImpl.submitForm_aroundBody0(FormServiceImpl.java:264)
at org.joget.apps.form.service.FormServiceImpl$AjcClosure1.run(FormServiceImpl.java:1)
at org.springframework.transaction.aspectj.AbstractTransactionAspect.ajc$around$org_springframework_transaction_aspectj_AbstractTransactionAspect$1$2a73e96cproceed(AbstractTransactionAspect.aj:66)
at org.springframework.transaction.aspectj.AbstractTransactionAspect$AbstractTransactionAspect$1.proceedWithInvocation(AbstractTransactionAspect.aj:72)
at org.springframework.transaction.interceptor.TransactionAspectSupport.invokeWithinTransaction(TransactionAspectSupport.java:281)
at org.springframework.transaction.aspectj.AbstractTransactionAspect.ajc$around$org_springframework_transaction_aspectj_AbstractTransactionAspect$1$2a73e96c(AbstractTransactionAspect.aj:70)
at org.joget.apps.form.service.FormServiceImpl.submitForm(FormServiceImpl.java:261)
at sun.reflect.GeneratedMethodAccessor669.invoke(Unknown Source)
at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:213)
at com.sun.proxy.$Proxy30.submitForm(Unknown Source)
at org.joget.apps.app.service.AppServiceImpl.submitForm(AppServiceImpl.java:1343)
at org.joget.apps.app.service.AppServiceImpl.completeAssignmentForm(AppServiceImpl.java:392)
at sun.reflect.GeneratedMethodAccessor712.invoke(Unknown Source)
at com.sun.proxy.$Proxy57.completeAssignmentForm(Unknown Source)
at org.joget.apps.userview.lib.InboxMenu.submitAssignmentForm_aroundBody40(InboxMenu.java:470)
at org.joget.apps.userview.lib.InboxMenu.submitAssignmentForm_aroundBody41$advice(InboxMenu.java:95)
at org.joget.apps.userview.lib.InboxMenu.submitAssignmentForm(InboxMenu.java:1)
at org.joget.apps.userview.lib.InboxMenu.submitForm_aroundBody38(InboxMenu.java:398)
at org.joget.apps.userview.lib.InboxMenu.submitForm_aroundBody39$advice(InboxMenu.java:95)
at org.joget.apps.userview.lib.InboxMenu.submitForm(InboxMenu.java:1)
at org.joget.apps.userview.lib.InboxMenu.handleForm_aroundBody32(InboxMenu.java:302)
at org.joget.apps.userview.lib.InboxMenu.handleForm_aroundBody33$advice(InboxMenu.java:95)
at org.joget.apps.userview.lib.InboxMenu.handleForm(InboxMenu.java:1)
at org.joget.plugin.enterprise.DataListInboxMenu.getJspPage_aroundBody20(DataListInboxMenu.java:156)
at org.joget.plugin.enterprise.DataListInboxMenu.getJspPage_aroundBody21$advice(DataListInboxMenu.java:95)
at org.joget.plugin.enterprise.DataListInboxMenu.getJspPage(DataListInboxMenu.java:1)
at org.joget.apps.userview.model.UserviewMenu.getReadyJspPage_aroundBody12(UserviewMenu.java:132)
at org.joget.apps.userview.model.UserviewMenu.getReadyJspPage_aroundBody13$advice(UserviewMenu.java:95)
at org.joget.apps.userview.model.UserviewMenu.getReadyJspPage(UserviewMenu.java:1)
at org.joget.apps.userview.service.UserviewUtil.getUserviewMenuHtml(UserviewUtil.java:94)
at org.apache.jsp.WEB_002dINF.jsp.ubuilder.view_jsp._jspService(view_jsp.java:636)
at org.apache.jasper.runtime.HttpJspBase.service(HttpJspBase.java:70)
at org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:443)
at org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:385)
at org.apache.jasper.servlet.JspServlet.service(JspServlet.java:329)
at org.apache.catalina.core.ApplicationDispatcher.invoke(ApplicationDispatcher.java:728)
at org.apache.catalina.core.ApplicationDispatcher.processRequest(ApplicationDispatcher.java:467)
at org.apache.catalina.core.ApplicationDispatcher.doForward(ApplicationDispatcher.java:392)
at org.apache.catalina.core.ApplicationDispatcher.forward(ApplicationDispatcher.java:311)
at org.springframework.web.servlet.view.InternalResourceView.renderMergedOutputModel(InternalResourceView.java:168)
at org.springframework.web.servlet.view.AbstractView.render(AbstractView.java:303)
at org.springframework.web.servlet.DispatcherServlet.render(DispatcherServlet.java:1257)
at org.springframework.web.servlet.DispatcherServlet.processDispatchResult(DispatcherServlet.java:1037)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:980)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:897)
at org.joget.commons.util.AnalyzerFilter.doFilter_aroundBody0(AnalyzerFilter.java:17)
at org.joget.commons.util.AnalyzerFilter$AjcClosure1.run(AnalyzerFilter.java:1)
at org.aspectj.runtime.reflect.JoinPointImpl.proceed(JoinPointImpl.java:149)
at org.joget.commons.util.AnalyzerAspect.analyzeRequests(AnalyzerAspect.java:54)
at org.joget.commons.util.AnalyzerFilter.doFilter(AnalyzerFilter.java:17)
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:262)
at org.joget.apps.app.web.ExpireFilter.doFilter(ExpireFilter.java:44)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:478)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:140)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:342)
at org.apache.coyote.http11.Http11Processor.service(Http11Processor.java:803)
at org.apache.coyote.AbstractProtocol$ConnectionHandler.process(AbstractProtocol.java:868)
at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1459)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
at java.lang.Thread.run(Thread.java:745)
      Hi, the error message says "Static method parseInt( [Ljava.lang.String; ) not found in class'java.lang.Integer' : at Line: 26". That means there is no such method parseInt taking a String array. Instead if you check the Java API parseInt expects a String.
