Hi experts,
I need to make the approval flow go to 4 approvers at the same time instead of one by one. But the system only choose to route to only one instead. Is this actually possible to do in Joget.
      Try changing the Route - Split Type to "AND". You can learn more about Process Routes here.
        Thank you so much Chris Angel. I never thought the solution is that simple!
