Hello,
When manipulating a Collection in Bean Shell Tool, I wanted to use the Java 8 stream API (myCollection.stream().filter().andsoon)
In my code I have a collection of WorkflowActivities activities and I want to find the first for which ActivityDefId = "firstMb1" :
Collection activities = workflowManager.getActivityList(processId, null, 30, null, null);
//get user who completed previous activity BM1. Needed : processdefid processid and BM1 activityDefID
WorkflowActivity bmActivity1 = new WorkflowActivity();
WorkflowActivity bmActivity1 = activities.stream()
	.filter(a -> "firstMb1".equals(a.getActivityDefId()))
	.findAny()
	.orElse(null);
But this does'nt work :
ERROR 01 août 2019 06:24:43 org.joget.apps.app.lib.BeanShellTool - Error executing script
Parse error at line 36, column 20. Encountered: >
It actually is my lambda expression that seems to rise an Error.
Any ideas?
Baptiste
      The parsing issue comes when you write a lambda expression in bean shell. However, i tested the same code by writing a plugin(store/load etc) in a maven plugin and then upload it on Joget and tried, it works.
      Solution:
      Write your maven plugin with the same code instead of bean shell.Guideline for developing a plugin .
        Hi, I believe BeanShell only supports a subset and not the full Java syntax https://github.com/beanshell/beanshell/wiki/Basic-syntax. So stuff like the stream API and generics are not supported.
