I have three select boxes. The third selectbox has to be show information based on the first two selectboxes.
  • Selectbox 1 - Pulls data from form A
  • Selectbox 2 - Pulls data from form B
  • Selectbox 3 - Pulls data from form C, but is filtered from A and B
Not sure how to do this
      found some links in the KB that might help you:
      Dynamic Cascading Drop-Down List
      Ajax Cascading Drop-Down List - includes a link to Joget Marketplace with a tutorial App
      Hope this helps
      1. Briant Fletcher
        When you select SelectBox 1 it populates Selectbox 2. Now based on those two selections Selectbox 3 is populated.
        This is what I trying to do and it's not working.
      2. Ian
        I don't think its possible to have two field IDs to control the options of Selectbox 3 in the same form as Selectbox 1 & 2. I suggest to separate it into 2 Forms.
        Here's what I did:
        First, create the necessary tables for Form A,B,C. Next create a process with two activities.
        Map the 1st Activity with a form that contains selectbox 1 & 2 using Dynamic Cascading Drop-Down List method with each selectbox and assigned to a workflow variable each.
        Then in the next activity, create a form that contains selectbox 3 and use the JDBC Binder to populate the options.
        Here's an app as reference: APP_dynamicSelectbox-1-20191018110347.jwa
        Hope this helps.
