I want to change the name of the file uploaded to the form.
Can anyone recommend me about this?
Thank.
      Using Beanshell to rename it.
      You may using beanshell in "Post Form Submission Processing tool"  then direct rename to in folder .
       refer to following link : https://stackoverflow.com/questions/1158777/rename-a-file-using-java/1158792
        Found someone asking something similar. Looks like you have to customize your own plugin.
        Changing Filename on form based on other fields
