How can we have SUMPRODUCT in a calculated field?
Column A and Colum B Each row value be multiplied and added up in a single field ?
      Hi - if you are using professional or enterprise you can leverage the Calculation Field already baked into joget. community users would leverage a custom html with javascript to perform calculation such as the example below.
      <script>
          function calculateTotal(amount) {
              var disc = FormUtil.getField("disc").val();
              if (disc === undefined || disc === "") {
                  disc = "0"; //set a default
              return amount * (100 - parseFloat(disc)) / 100;
      </script>
      see: calculation tip in spreadsheet (subform)
      Good Luck
      tony
