Hi, from the error message it seems the process routing is incomplete or incorrect. Perhaps you can share a screenshot of your design with more details.
Thanks, I fixed it!
Hello,
I am creating a process where the user can select the recipient by checking checkboxes on a form.
I am using a route(split type and), and based on the checkbox value it should send email to each recipient. It works perfect when I choose only one, but when I choose more than one it does not.
I have also set the workflow variable, that I use on the condition route
Error I see on the server log is: 5 Shark - Process [key=94_app2_process1,mgrname=app2#14#process1] will try to finish after [Process Id=94_app2_process1, Id=202_94_app2_process1_route1, ba=null, ActDefId=route1] is executed because kernel is configured not to allow hanging and not to rollback
