I recently discovered the template AdminFaces and would like to know if it can be used with Joget Workflow.
More infos at :
https://github.com/adminfaces/admin-template
THANKS
      Thanks for your answer.
      I'll try with Userview Theme Plugin.
        You can developed your own userview custom theme using Userview Theme Plugin.
        Or use JSON API to call Joget from an external application.
