I have created a list from a form. I put an extra filter condition that is working fine. The extra filter is  the one below:
e.customProperties.receiver like '%#currentUser.username#%' or e.customProperties.sender ='#currentUser.username#'.
Sender a receiver are a text field and a hidden field in the form.
But if I add a filter column in the list design, and I try to filter by that column , it does not work. No errors are showing , but the filter is not returning the right filtered list.
      I think I fixed it, It is important to enclose in parenthesis the extra filter
      (e.customProperties.receiver like '%#currentUser.username#%' or e.customProperties.sender ='#currentUser.username#)
        Hi genti
        It would be useful if you can attached a sample app for the community to help you check. Thanks.
