I am using Download PDF Datalist Action Plugin to generate pdf . I need to change the css of the pdf , but til now I manged to change just the font of labels and not the font for values . I used the code below
.form-cell .label {font-size: 14px;}
Can somebody please help what code to use for changing font of values? Thanks!
      Maybe you could try the below CSS in "Configure Download PDF Action > Formatting (CSS)" property field.
      * {font-size: 20px !important;}
      1. genti
        It works, but I do not want to have same font for every element in pdf. I have text in header as well, and I want to have it different font size.
      2. Justin
        For the CSS, you can specify only to apply the style to an element type or class or id.
        See how to do so here: https://www.w3schools.com/css/css_selectors.asp
      3. genti
        Hi, I know how css works, but I need to know what is the element name for form values
      4. Neta da Silva
        Did you try
        .form-cell-value
