Hi Folks,
I am considering to use Joget On-Demand service, and I read in FAQ there is no option for direct access to database, because it is multi tenant. Is there any way to create stored procedure, index, and view in Joget Cloud?
Thanks,
Peter
      Hi, according to https://www.jogetcloud.com/on-demand.html I believe there are options for both multi-tenant and dedicated. You should be able to have direct access to the database for dedicated plans.
        I think Joget On-Demand is for those who want to use Joget as a service without worrying about the infrastructure or the need to integrate with other systems.
        If you require control over the infrastructure and have specific integration needs then I think it’s recommended to have your own installation either on-premise or a dedicated hosting on the cloud, from either Joget's hosting partners or your own preferred cloud provider.
