When do we use hidden field element
      I don't fully understand the question, but hidden fields are useful for providing key-type fields or fields that reflect process states, but which in no case should be seen or manipulated by the user.
        Check this article out on the use case - Hidden Field
        Typically, I use it to set "Status" so that in the Datalist, I can filter the data display according to the "Status" that is selected. E.g. New, Pending, Expired, etc.
        Best is to see an example in the HR Expenses App from the Joget Marketplace - https://marketplace.joget.org/jw/web/userview/mp/mpp/_/vad?id=hr-expenses-v1
