Hi, the error is "java.io.StreamCorruptedException: invalid stream header" which might indicate some database encoding issue. What database are you using? If you are using MySQL for example you need to ensure that UTF-8 is used.
My reference link (https://dev.joget.org/community/display/DX7/Build+Source+Code+on+Windows)
An attempt was made to compile Joget, but an error occurred while compiling
Log: org.joget.workflow.model.TestWorkflowManager.txt
Can you give me a hand?
