Hi all,
I am trying to Build Source Code on Windows and currently am hitting this error upon mvn clean install:
[ERROR] Failed to execute goal on project wflow-wfengine: Could not resolve dependencies for project org.joget:wflow-wfengine:jar:7.0-SNAPSHOT: The following artifacts could not be resolved: EnhydraShark:shark-maven:jar:2.0.1, EnhydraShark:sharkscripting-standard:jar:2.0.1, EnhydraShark:sharkclientutilities-misc:jar:2.0.1, EnhydraShark:sharkinstancepersistence-dods:jar:2.0.1, EnhydraShark:sharkinstancepersistence-dodslayer:jar:2.0.1, EnhydraShark:sharkrepositorypersistence-dods:jar:2.0.1, EnhydraShark:sharkrepositorypersistence-dodslayer:jar:2.0.1, EnhydraShark:sharklogging-standard:jar:2.0.1, TogetherRelationalObjects:dbmanager:jar:7.1-1-professional, TogetherApplicationFramework:eaf-api:jar:7.1-1-community, TogetherApplicationFramework:eafconfreader:jar:7.1-1-community: Could not find artifact EnhydraShark:shark-maven:jar:2.0.1 in central (https://repo.maven.apache.org/maven2) -> [Help 1]
EDIT:
When I try to Install the 3rd Party Libraries I got the following Error:
[ERROR] The goal you specified requires a project to execute but there is no POM in this directory (C:\Users\xxx\install-libraries). Please verify you invoked Maven from the correct directory. -> [Help 1]
org.apache.maven.lifecycle.MissingProjectException: The goal you specified requires a project to execute but there is no POM in this directory (C:\Users\xxx\install-libraries).
I can't find the POM file from the download link.
Can someone please help me. Thanks in advance.
      UPDATE:
      1.  I update the Maven to version 3.8.5 as per Azrul's advice.
      2. Then, I re-install back the Install Libraries from Build Source Code on Windows#2.Install3rdPartyLibraries as per Anders advice.
      Now, am able to build successfully. Thanks both.
        Hi..any update on this? I still not able to build the source code on Windows
          Hi, it appears you are missing required dependency libraries. You'll need to install these libraries by following the instructions at Build Source Code on Windows#2.Install3rdPartyLibraries.
          1. Harita
            Hi Anders,
            I have tried to follow instruction as per the link.
            When I try to Install the 3rd Party Libraries I got the following error:
                 [exec] [INFO] ------------------< org.apache.maven:standalone-pom >-------------------
                 [exec] [INFO] Building Maven Stub Project (No POM) 1
                 [exec] [INFO] --------------------------------[ pom ]---------------------------------
                 [exec] [INFO] ------------------------------------------------------------------------
                 [exec] [INFO] BUILD FAILURE
                 [exec] [INFO] Total time:  0.183 s
                 [exec] [INFO] Finished at: 2023-02-10T14:04:05+08:00
                 [exec] [ERROR] NullPointerException
                 [exec] [ERROR]
                 [exec] [ERROR] To see the full stack trace of the errors, re-run Maven with the -e switch.
                 [exec] [ERROR] Re-run Maven using the -X switch to enable full debug logging.
                 [exec] Result: 1
            And upon further debugging I see this error:
            Can please help to advice me?
          2. PT
            what version of maven are you using? i used 3.9 and got the same error. Then i switch to 3.8.5 and its working
