I have a document versioning desktop application which stores document and images and i need this system to be the  starting point for the Joget process; so that after scanning the documents and images to initiate a new joget process.
so the approach i am thinking to follow is as follow:-
1. To Initiate the Joget process from the desktop application using avilable JSOP API, such as:-
/jw/web/json/workflow/process/start/processanme:26:process1
2. after that to send an email to the associated user regarding the new process instance
3. the user will login to the joget web console or user view then review the images and documents and finally  approve or reject the activity.
4. and the process contiune if needed ....
But the problems i am facing is as follow:-
1. How can I pass the URL of the associated documents and images from the desktop application to the Joget system using the above JSON API call. Baring in mind that  the documents and images are stored inside a folder in the server and not on the database .
2. how can i display the scanned documents and images in the Joget forms.
Thanks in advance for any help.
